Hey all
Its been a while since i custom built a PC. Here is what i have thrown together for parts http://pcpartpicker.com/p/wtQe do you think this would be a good build for gaming and video editing? any advice is welcome
Thanks
That looks good for gaming, you should have no issue maxing out most of the current games.
I would however suggest a better keyboard, I think you'd be limiting yourself. Not a $100 logitech g15 or anything, but you might do well with a nice Razer or something.
go with less ram, you wont be able to utilize more than 8GB and it wont help you in games
also you dont need a 750W PSU, get a 550-650W PSU
spend the money you save on getting a 7870 instead
go for a hyper 212 evo
okay will do thanks!
An i5-3570k might be a better option if you plan on video editing.
