im new to PC gaming,but i absolutely love it. My question is "what is more effiecient for gaming,building a PC or buying a Pre-built PC ?" Cyberpower will build the PC for you, but ive heard really bad things about them. Ive never build a PC before but im confident in my ability to do so.
It is always cheaper to build your own and I can say that confidently. When you build your own computer you get the freedom of choosing exactly what you want, unlike buying something pre-built. Also some of those companies use really low quality components, but charge you way more than what it's worth. Just build your own, it is fun, easy, and rewarding.
Find whatever model you like and then put the same parts in pc part picker .com to see which one would be cheaper and by how much. Most of the time self built is about 20% cheaper >$500, 10% cheaper <$500.
I believe self-built is cheaper, as you can choose what graphics card you want, and you can get a really good one, and get a CPU that'll work great as well... i5 or amd 8350 would probably be good, but since Im new to building computers, I can't really help out with finding parts...
I've never ever seen a prebuilt cheaper than all of its parts together. In addition, they almost never give you a full list of parts so you don't know whether they put there a decent PSU or motherboard.
Also, as far as I know, you get warranty for the whole thing and not each part separately so if you make any modifications, you void it.
It was mainly so they could see the difference directly. If you catch a company getting rid of stock i've seen some sales at a lose, or atleast at cost.
There are advantages and disadvantages for both options.
For example:
Build your own
Advantages of building your own PC - It's mostly cheaper, you have your own options and any crazy ideas you want to implement in your build, never get to deal with prebuilt vendors' hassles so you are able to built your own PC up to your expectations and get to have fun and learn while in the process. Depending on the circumstances, this type of skill could be an addition to your resume.
The disadvantages - Requires plenty of time to research for each individual parts, eg, must be careful to choose the right CPU for the motherboard's socket or else there will be a mismatch or be manufacture wise, just in case their customer service is poor, must be gentle and slow when assembling and make sure you have the right tools.
Prebuilts
Advantages of a prebuilt - All the assembling has been done for you, quicker (depending on the time the vendor took), no need to get your hands dirty and depending on which vendor you picked,they may be loyal to you when it comes to warranties and/or RMA processes, unless your prebuilt is dated which in this case, the vendor can't do anything.
Disadvantages - Some prebuilt PCs may not be adequately built to higher standards as you would expect, ok, this is where everyone gets tough against prebuilts; costs vs the performance you get; there may be vendors (most of them IMO) that will rip you off, unless the price you think is justifiable when you do the working out which may not be the case, sometimes the option to alter any parts you would like to swap may not be available and there may be vendors that will be very cheeky when it comes to the warranties and/or RMA process, whereas you could just deal with this directly to the store you pruchased the part(s) from or with the manufacture (mostly).
Chances are, I like building things, so the 1st option would be my pick.
