right. i am looking to play games like bf4 at high - ultra at 1080p not going under 30fps hopefully keeping at around 60. i am in NZ and will list all the parts i have in mind. i really cant spend over $1550NZD TOPs. i don't mind if you guys completely change everything, but all i want is a good bf4 experience and a good looking case
case- bitfenix raider gunmetal window with added 200mm spectre fan (obviously bought separately)
CPU - fx 8350 8 core
GPU - sapphire r9 270x dual-X OC
mobo - m5a97 r2.0
CPU cooler - hyper 212 evo
RAM - hyper x 1600 MHz cl9
HDD - 1tb hdd (i can upgrade later and buy external to back up)
crap, cheap optical dvd drive
PSU - corsair RM 650 modular 650w power supply
thanks guys for reading and thanks in advance for any advice. all my peripherals are sorted, its just the build that concerns me at the moment, i am going to the cheapest trustable online shops so if you can recommend any, that would be awesome.
Hi, now when mantle is comming and we saw its performance increase in BF4 you could go FX 6300 + r9 280x for ultra 1080p BF4 gaming at 60FPS. I dont know if the price will be in your budget after changing those 2 components because I dont know in which store are you buying or what are the price in your country.
I made 3 sollid options if you allready own your case, then i think one of these builds are beasty.
The second option i know the R290 reference models are a bit loud on full load, but they are alot cheaper, then non reference. so if you dont care to much about a loud stock gpu fan, then i think the second option is realy a beast.
The First option, is realy a beast, but just over $1550 unfortunatly.
The Third option,Is also very decent, can maxout all games at 1080p aswell. Basicly powerfull enough for your needs.
even a 280X beats a GTX770 2GB "price compairison NZ" in alot of games, especialy games like skyrim with tons of mods added to it. because the 3GB of vram realy comes handy on those mods.
