Building a pc (Help please)
Hi everyone, this is going to be my third, I have a bit of excess money and so I decited to build a editing/Sound editing/gaming/all purpose rig so if any one can help me that would be very nice. :P
these are the parts:
case:COOLER MASTER HAF X Blue Edition RC-942-KKN3 Black Steel / Plastic ATX Full Tower Computer Case
motherboard:ASUS Crosshair V Formula-Z AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Gaming Motherboard
processor: AMD FX-8350 Vishera 4.0GHz (4.2GHz Turbo) Socket AM3+ 125W Eight-Core Desktop Processor
Ram: Kingston HyperX Beast 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 2133PCI Express 3.0 x16
Psu:EVGA SuperNOVA NEX1500 Classified 80+ Gold
HDD/SSD: Western Digital WD Black WD4001FAEX 4TB 7200 RPM;SAMSUNG 840 Pro Series MZ-7PD512BW 2.5" 512GB SATA III MLC Internal Solid State Drive
Heatsink:XIGMATEK Dark Knight II SD1283 Night Hawk Edition CPU Cooler
Thermal paste:Tuniq TX-4 Extreme Performance and Exceptional Reliability Thermal Compound
Gpu:GeForce GTX 680 Classified 4GB 256-bit GDDR5 PCI Express 3.0 x16 (x2)
OS:  Microsoft Windows 7 Ultimate
Monitor: ASUS PB Series PB278Q 27" 5ms (GTG) WQHD HDMI Widescreen LED Monitor
soundcard:Creative Sound Blaster Z Series ZXR (70SB151000000) PCI Express x1 Interface Sound Card
wireless adapter:ASUS PCE-AC66 Next Generation AC Dual-Band Wireless Adapter IEEE 802.11ac, IEEE 802.11b/g/n PCI Express
Optical Drive:ASUS BW-12B1ST
Extras:COOLER MASTER Megaflow 200 R4-LUS-07AB-GP 200mm Blue LED Case cooler; McAfee Internet Security 2013; McAfee AntiVirus Plus 2013; BELKIN BP112230-08 8 Feet 12 Outlets 4320 Joules Pivot-Plug Surge Protector
Freebies from NewEgg:Logitech M500 Tilt Wheel USB Corded Laser Mouse;CORSAIR Vengeance 4GB 240-Pin DDR3 SDRAM DDR3 1600
Any help is appreciated,I just want to make shure that everything fits in well together no problems.
P.S. i do not know how long i will need the network card for depends if i want to spend the money for my internet provider to get me another router for my studio so i can have eathernet.
Create a account on PC parts picker, and post a build, it will make it a lot easier for us to help you.
http://pcpartpicker.com/user/wattledgold/saved/#savedbuild_307708
here it is
Looks great. Only two things I would change. Swap that EVGA power supply with a corsair AX1200. you don't really need 1500 watts. Also I would swap the dual 480s with a gtx titan, it will give you slightly worse performance, but it will generate less heat, consume less power, and you can eventually put up to 3 of them in SLI.
I managed to squeeze dual titians into your budget.
http://pcpartpicker.com/p/K9zs
Thank you. i.............. dont know what else to say
