Building a PC for the first time
Hi guys,
Next week I'm going to buy a new pc.
I looked at a few components, but I need to know if they are compatible.
And I need to choose a graphics card under $180
here is the list:
ASUS F2A55-M - Socket FM2 - Micro-ATX
AMD A series A10-6800K - 4.1GHz - Socket FM2
Crucial Ballistix Sport - Geheugen - 8 GB : 2 x 4
Cooler Master N200
Corsair CX600M - 600 Watt 80+ bronze
ASUS DRW-24F1ST - DVD
I only need a graphics card that is compatible and not to expensive.
Thanks,
Luke Zoetebier
P.S: if you need links to the components please say so.
Why are you looking at getting a dedicated GPU, if you are purchasing an APU?
oh yeah you're right.
Was already thinking of buying a MSI 970A-G46 - Socket AM3+  instead.
And a AMD FX 6350 Black Edition - 3,9GHz - Socket AM3+
But which one is better?
i would personaly advice to pickup a FX6300 with Asus M5A97 R2.0 mobo and if i´m right you can get a Radeon 7950 for arround $180.
This will give you more gaming performance.
p.s that msi board has a weak powerphase 4+1 i would personaly advice not to go higher then a FX6300 95W tdp cpu on that board. by the way the performance diffrence between the FX6300 or FX6350 is realy minimal.
http://pcpartpicker.com/p/NIzF
yeah that Asus M5A97 R2.0 mobo is really nice, going with that one.
Only problem is I don't live in America, so when I buy it online I pay way more.
That's why I buy it of a local hardware shop but they don't have everything.
Alright, so the Asus M5A97 R2.0 mobo and a AMD FX 4350 Black Edition  4.2GHz  Socket AM3+
Think I'm going with that.
sorry if I make dumb choices or whatever, this is my first time.
please feel free to correct me
it would be a better way to pickup the FX6300. where do you live? and are there any online shops overthere?
I live in the netherlands, there are some online shops.
But I might just buy a pc that is already built, and then buy a new graphics card
