Me gal is in dire need of a new PC, so we have hit our wise heads together and I've been given the job to spec a build for her, The PC will be mainly used to play games, such as Skyrim and a lot of WoW, she want's to be able to use the PC for some Photoshop editing, so I thought it would be nice to have a somewhat good CPU as well. What I need the collective wisdom of the community for is to see if the spec looks good, or if I'm missing something, or if any part of the build will cause problems. Well here's the list of components, all should be the right components except the RAM, which are in the Potenza series, but it still has the same Clockfrequency (1600Mhz) so I choose the one closest to the build.
Now I do not know what your budget is, but I assumed since you choose an 780 in there, you have a pretty high budget.
I changed the 8350 to an 8320 as it's the same thing, that you could basically just overclock it yourself and get the same overclock as you would on a 8350. You forgot a third party water cooler on a build like that. Especially for gaming you will want something that will keep you CPU cool and quiet while you game, so I went with the H100i. I downgraded your motherboard, even though as nice as a motherboard as it is, is a bit overkill for what you need. I went with the ASUS M5A99FX PRO, as it's a quality board, with everything you will want and helps keep on the ASUS theme you have going.
I added an SSD in there to help with boot times with windows, photo editor and the load times for Skyrim(it will not increase FPS). I also threw in a 1TB drive for holding all other games and programs you have. I changed the RAM to 1866 as she will be doing photo editing, she may need the extra speed and it only costs $2 more.
I kept your GPU in there, as it's a fantastic card, but you could also wait until the R9 290x hits the market as it is being called the "Titan Killer" and from some leaked benchmarks it will out perform the 780 and GTX Titan in most games, but these are rumors and should be taken with a pinch of salt. Also with the steam OS(being Linux based), Mantle, and the way gaming looks like it will be heading over to Linux soon, nVidia doesn't really play in that park so to speak, so AMD may prove to be the better solution for the future but that it solely my opinion.
I chose a quieter and more optimized case than the one you had chosen before. I believe a gaming PC especially something at that cost should be silent and have great air flow at the same time looking sexy. But cases are personal choices as you are the person who has to look at it everyday and also build in it. The case is also great to build in. I changed you PSU, to something with a little more juice for that 8320 and 780 and that comes Semi-modular, which will help in building the computer and keep it nice and clean looking. I also threw in a sound card to help with the gaming experience, instead of being stuck with dull onboard audio.
