Building a PC 400-600Euros
Hey guys, i would like to build a PC with low budget but i have some doubts, that i wanted u to anwser me:)
The setup that i was thinking was:
AMD A10 6800K 4-Core 4.1GHz Socket FM2 BOX 146,00euros
ASUS F2A85-M (Socket FM2) 79.50euros
CORSAIR VS550W VS Series 49euros
SEAGATE 1TB SATA III 64MB 7200 RPM 62euros
ASUS DVDRW 24X SATA Preto Bulk 19euros
CORSAIR XMS3 4GB DDR3 1600MHz CL9 PC12800 x2 65,50 euros
AEROCOOL Cyborg X 68euros
Its for comon uses, family , but also games. This is for my Kid, just 12 years old. I think this setup is enough but i dont know if i would go for a i5 4570 with/without graphic card, or and FX of AMD.
The pros cons, i dont really know:S
Thx for your time guys:)
It all depends on the games you will be playing. General use doesn't require much. If the games you will be playing are internet/mmo type games then I think an amd APU would be perfect for you. You might even not really need an a10 if you don't need much.
Some other considerations: The psu isn't ideal, I would go for another series in the corsair brand or even go for a be quiet model. But you don't even need 550 watts, you could get away with about 300 watts even. Get a 80 plus model ;). You could get yourself an ssd maybe, that would make things snappier.
