CHANGES ARE BOLD FOR YOU also forgot to change powersupply
okay people, i appreciate the click on my post!!! welcome to version 2.0 of my build! first and foremost what i am planning on getting:
Cooler Master HAF 932 Advanced - High Air Flow Full Tower Computer Case with USB 3.0 and All-Black Interior
EVGA GeForce GTX 980 Superclocked 4GB 256-Bit GDDR5 ACX 2.0 PCI Express 3.0
Intel Core i7-4790K Haswell Quad-Core 4.0GHz LGA 1150 Desktop Processor
MSI Z97-Gaming 7 LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
NZXT Kraken X61 (cpuc ooling)
CORSAIR AX series AX860 860W ATX12V / EPS12V SLI CrossFire 80 PLUS PLATINUM Certified Full Modular Active PFC Power Supply New 4th Gen CPU Certified Haswell Ready
WD BLACK SERIES WD2003FZEX 2TB 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
SAMSUNG 840 EVO MZ-7TE120BW 2.5" 120GB SATA III TLC(SSD) (used for OS)
SAMSUNG 840 Pro Series MZ-7PD512BW 2.5" 512GB SATA III MLC Internal Solid State Drive (SSD) $230 off on newegg
G.SKILL Trident X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900)
mouse and keyboard? easy!
mouse, Razor naga molten edition
Corsair K70 Gaming Keyboard with Red LED, Cherry MX Red
What i need: input, what do you think of the build? is there any issues that you might come with this build? is there anything better that you can recommend for around the same prices and/or cheaper of the same quality or better?
for god sakes people, i know its too much power, but the case comes built in with a bunch of fans and i plan on eventually running in sli w a second graphics card. a lil extra is never bad!! :D
