Building a new pc need to make sure it will work
HI im just coming from a ps3 and i want to build a pc and i have my parts picked out and i was wondering if you could tell me if these parts are compatible..  Parts listed below
1.GIGABYTE GA-G1.Sniper A88X FM2+ / FM2 AMD A88X (Bolton D4) SATA 6Gb/s USB 3.0 HDMI ATX AMD Motherboard
2.WD BLACK SERIES WD1003FZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
3.LITE-ON Black SATA DVD-ROM Drive Model iHDS118-04 - OEM
4.CORSAIR RM Series RM750 750W ATX12V v2.31 and EPS 2.92 80 PLUS GOLD Certified Full Modular Active PFC Power Supply
5.G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200) Desktop Memory Model F3-2400C11D-8GSR
6.AMD A10-6800K Richland 4.1GHz (4.4GHz Turbo) Socket FM2 100W Quad-Core Desktop Processor - Black Edition AMD Radeon HD 8670D
im wanting to get a graphics card please let me know what would be good thank you
So far looks fine, and that 6800k is gonna do rather well graphics wise for even modern pc games still, depending on the resolution. Great for 720p gaming, but around 1080p or so you'll probably have to bring down things like BF3 or BF4 to medium settings. See how the 6800k runs for you first, and then later on save up for a separate card to keep your system current
If you can afford it, i would suggest swapping the A10 for a Athlon X2 760K and pairing it with a GTX 660/HD 7870/ R9 270 wichever is the cheapest :)
The performance improvement would be huge!
cool thanks i was planing on getting an R9 270x will i run into any issues if i keep the a10
