Building a NEW PC. NEED SOME HELP
So i have this old acer aspire ax3400-e3202 desktop and the motherboard is gone. so i was thinking about building a new desktop with some old parts and some new ones. any suggestion to what i can do. i have around $350-450 (Canadian).
Parts i am going to use from old computer (unless find better ones chear)
Harddrive (500gb)
Cd drive
3 gb ddr3 (not sure)
AMD Athlon II X2 220 cpu (not to sure)
i need help or advice with the following parts
Case, Power supply, Motherboard, Cpu and gpu and ram(if cheap)
My budge it 350-450. If  i missed any parts let me know. Thanks in advance for your help.
http://www.ncix.com/products/?sku=69872&vpn=M5A97R2%2E0%20%26%20FX-6100&manufacture=Bundle%20Deals
This is the mobo and cpu I would get.
http://www.ncix.com/products/?sku=57910&vpn=Z9%20Plus&manufacture=ZALMAN%20TECH&promoid=1285
This case.
http://www.ncix.com/products/?sku=59615&vpn=P1550SXXB9&manufacture=XFX&promoid=1285
This PSU.
http://www.ncix.com/products/?sku=55544&vpn=996770&manufacture=Mushkin%20Enhanced&promoid=1360
This RAM.
http://www.ncix.com/products/?sku=77699&vpn=R6670-MD2GD3&manufacture=MSI%2FMicroStar
This GPU will also be ok. You wont be able to play many games but you have the option of upgrading your GPU later.
All of this came to a total of $434.95 CAD.
I would also recommend most of these parts, ESPECIALLY the Z9 Plus. It's the case that my rig uses and I absolutely love it.
