Hi there
I’m looking to build my own HighAvailability Shared Storage Cluster.
The ideal setup would be something I can build with my own hardware, and with as little hardware as possible.
In my current setup I’m running two Dell Poweredges connected to a Dell PowerVault DAS filled up with 2.5" SAS SSDs. Giving each Poweredge direct access to each SSD in the DAS enclosure.
Right now I’m using a combination of Windows Storage Spaces and Active Directory to handle the HA setup. But I would like to try something else.
I’ve been looking at TruenNAS Scale. And even though their website tells me that TrueNAS Scale should be able to make a HA setup with a DAS & 2 controllers, I’m being told (by iXsystems) that it’s only possible to do with their own hardware, not with my own.
But their description of a Shared Storage Cluster matches very well what I’m trying to build; “Two nodes are used to manage a shared ZFS pool.”
Is this possible to build a HA Shared Storage Cluster with my own hardware, but using some kind of Linux?
