Building a Gaming Pc
I have 950 dollars and im building a gaming pc. I dont have any old hard drives and i need a windows copy so that should be added into the build. I've been pricing everything out on amazon because thats were im going to be purchasing the hardware. If you think you can build a better gaming pc for me with an absolute max price of 950 dollars on amazon please respond. Here is what I have so far
gtx 760- 260 dollars- i got this off newegg because it is not for sale on amazon as of today
amd fx 6350- 155 dollars- amazon
GIGABYTE GA-970A-UD3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard- 100 dollars- amazon
nzxt source 210 elite black- 50 dollars- amazon
corsair cx750- 80 dollars- amazon
lite-on dvd drive- 22 dollars- amazon
corsair vengeance 8gb ram- 60 dollars- amazon
WD blue 1tb- 66 dollars- amazon
cooler master hyper 212 plus- 30 dollars- amazon
windows 7- 90 dollars- amazon
This all comes out to about 925 dollars, but keep in mind prices tend to fluctuate a lot
Instead of 212 evo get an fx 8350 and this psu http://www.amazon.com/SeaSonic-550-Watt-CrossFire-Certified-SSR-550RM/dp/B00918MEZG/ref=sr_1_19?m=ATVPDKIKX0DER&s=pc&ie=UTF8&qid=1372187934&sr=1-19
Wait, why would he not get the 212 Evo? Did you mean instead of the FX 6350?
Other than that, yeah, I don't think you need a 700 watt PSU, if you plan on sticking to single GPU solution. That said, depending on your budget, and needs, you could spend the left over money on a better GPU, or CPU.
I'm saying that I would rather run an 8350 with the stock cooler than a 6350 with a 212 evo because youu can always add a cpu cooler.
