Building a gaming PC
Hey guys, after yesterday I decided to change my build around a bit. I am now looking to overclock and I am trying to keep it under $900. This is my build so far, http://pcpartpicker.com/user/TimmyTimTim/saved/1t8e , any suggestions would be greatly appreciated.
Thanks,
Tim
Get a less expensive case and an fx 8350 With $900 you can do alot
I got that Case because of the 5 fans that are included so if I overclock it wont over heat
