Building a decent pc
Hey peoples, I'm some what new to building a pc and I've done a lot of research into pc's. I have a buget of lets say $1500. So I have chosen this http://pcpartpicker.com/p/EPGq and i was hoping to get get some expert help in fine tune this into a good gaming rig.
Thanks, zakk
p.s. I used http://teksyndicate.com/videos/build-best-pc-under-1300-september-2012 as a reference
660 TI
Lets be honest a 7870/7850 would be better for the price unless you cum buckets over PhysX or only play Nvidia optimised games.
Well, may I ask what exactly you're going to use it for? Because honestly you could get a lot more for your money.
"Elite" gaming
http://pcpartpicker.com/p/F66z
Get rid of theat RAM, its pointless, get 8Gb of 1600mhz ram, and then buy a 7950 with the money you save, id also just get a 7200RPM 1TB HDD as it will be faster than the 5900RPM drive (which are also about 20$ cheaper)
But im curious, is your budget 1000$ or 1500$ ?
Yes, I find my computer runs much better without RAM.
he told him to change the ram hes using not get rid of it...
