Building a computer need help updated
so here is my set tell me if it's good or not
Patriot Memory Viper 3 Series DDR3 16GB 1866MHz (PC3 15000) Memory Kit PV316G186C0K -
Crucial m4 256GB 2.5-Inch Solid State Drive SATA 6Gb/s CT256M4SSD2
NZXT Technologies HALE90 V2 1000W ATX12V/EPS12V Modular 80 Plus Gold Power Supply NP-1GM-1000A
looked it up on new egg says it's SLI crossfire ready
Seagate Barracuda 7200 3 TB 7200RPM SATA 6 Gb/s NCQ 64MB Cache 3.5-Inch Internal Bare Drive ST3000DM001
Corsair Hydro Series H100 Extreme Performance Liquid CPU Cooler (CWCH100)
ASUS SABERTOOTH 990FX R2.0 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
AMD FX-8350 FX-Series Eight-Core Processor Edition, Black AM3 FD8350FRHKBOX
NZXT Crafted Series ATX Full Tower Steel Chassis - Phantom Black
NZXT 200MM Silent 700 rpm LED Fan - FS-200RB-BLED (Blue)
reason for the 200mm fan the case I'm getting only has one on top and I need 2 for the h100 setup in the case
good build?
total-$1,285
I'm going to get 2 7970's I'm stuck between gigbyte and XFX I heard that they got gigabye to 1500hz or what ever it's called but the XFX has a lifetime warranty and is it going to be stable???
I really need your help people please it's my first build I'm researching everyday lol
good build, go with the gigabyte 7970's. consider a slightly better ssd?
tom
For the graphics cards, I would go with the lifetime warrenty. For the SSD, The crucial M4 series are a good mainstream SSD. Very reliable indeed. Personal experiance with one of my clients.
Edit: PC Part Picker will also make a good tool to use
will 2 gigabyte or xfx's 7970's fit in a nzxt phantom case the mothboard is going to be a sabertooth and the power supply is going to be a Thermaltake Toughpower Grand 1050W
umm... the h100 comes with 2 (loud) fans. also, it uses 120mm fans, not 200mm.
gigabyte doesn't make very good graphics cards. XFX does not have a lifetime warranty anymore, but it's not bad in any case. I don't think any current GPU will get to 1.5 ghz w/o liquid cooling, and even then, I really don't think it's possible. take a look at ASUS cards and the MSI lightning card, both are widely known for reliability and overclockability.
http://pcpartpicker.com/part/msi-video-card-r7970lightning
http://www.amazon.com/dp/B00739TCH8/?tag=pcpapi-20
th 200mm fan is for the top of the phantom and will 2 7970's fit in there?
the thing about the h100 is that you can get a block in the middle of the 2 200mm fans and the put screws throught the h100, the block and into the 120m hloes that are there and thus the 200mm act like pull fan
yes they will fit.
