Building A Computer, How can I save some cash? (COMP BUILD INSIDE)
Anyway I could improve my build and save money? Total is a little under 3,000$ USD, any tips guys?
Oh Also, this is my first time giving building a computer by myself, so am I missing anything? Sorry for that late add in part to my post sorry for double posting.
cosair cases has poor airflow and are overly expensive, they look sexy but that's about it
instead of the AF120s I would get SP120 performance for your H100
Could you suggest a diffrent case? I'm just kind of following the newegg guide atm, I really don't know what case to get all I know it has to be mid range because that's what the motherboard size is as well. But yeah any kind of case you would recommend?
Cosair cases dont have bad airflow. They just aren't as good as most because of the dust filters restrict some of the flow. However my C70 moves more air then my HAF 922 did when I put Bitfenix Spectre Pro fans on
What features are you looking for? Dustfilters? USB 3.0? How many bays will you possibly use?
Also remember that you can always get different fans that move more air then the stock fans (and that are more quiet)
I'm looking for something with dust filters I'll only be using max 4 drive bays I don't know if you mean including the CDROM Reader (if you do then it is still 4), and honestly that's it. Nothing really too flashy I don't want something that looks too out there. lol
for 189 bucks I want more than just 2 intake fans and 3 exhaust, that seems pretty poor for the price
I'll make a build later tonight, stuff to do
