My roommate is trying to build a cheap gaming computer. As far as I know, he only really wants to play one game on it. Phantasy star online 2. according to sega the game requires
an intel core 2 duo e6300 cpu and nvidia GeForce 7800T or better graphics.
im looking into an apu build because he doesnt want to spend that much money on a computer espeically since he isnt planning on using it as his main gaming machine, (xbone...).
Im basing my idea for a build of a linus tech tips video where he reccomends
an amd a10-6790k apu. Will this be able to handle the game?
Also the build reccomends 8gb of ram which is pretty much the standard now but the game only requires 1.5gb of ram to run. Would I be able to skimp on ram and only get 4gb? or will windows 7/8 hog to much memory for the game to run smoothly?
Not sure if you need windows or not.
Tower only: http://pcpartpicker.com/p/2JlGN
W/ windows: http://pcpartpicker.com/p/2JlNC
The first build will perform quite a bit better than the second.
Awesome thanks. Dont know about windows but thats his problem Im only looking into the hardware for the computer.
Alright if it requires a 7800T or better than APU would chop it up but I suggest the new Kaveri A10 APU... and a small board if you do not want it to be above 350. (Mini I TX is recommended here) then head on over to Silverstone or bit Fenix for their itx cases as they come with power supplies saving you on cost .. good luck
You're not gonna fit that in 300-350.
A10-7850k is $185
Silverstone/Bitfenix cases are not cheap; at least $50 for a nice case. If you want one with a power supply, you're often looking at $100+ cases
Mini ITX boards cost more than M-ATX, and FM2+ is new, making each motherboard at least $106 according to pcpartpicker.
PSU is $25 after a mail in rebate.
RAM is $75.
Yeah, too expensive.
Yeah he might be willing to go to around 350 but not more than that. Though depending on if he has a case already might be able to stretch the budget for internals a little further.
Some tech noob's build looks solid. Remember to buy that exact ram he recommended, don't buy slower ram.
Yep. That APU will need fast ram :)
