This is my first ever build so I know theres something I can do better with part selection. I am probably going to buy some parts from Micro Center and others from newegg. I have a Micro Center close by so its not a big prob going there. I would be willing to go to $1000 but i really want to keep it where it is. Micro center isnt working right now so im just going to post the parts as if I were buying from Newegg
Since overall im under and going to be under because im buying from Micro Center, thats where i need help. Because I know with the extra $ i should get an SSD to go along with the build.
I wouldn't hold your breath on rebates, they also give excuses to void your warrentys to companies, and you only get it about 12 weeks after you send it
well your build only uses about 400w Max after overclocking both the CPU to 4.5Ghz and the GPU as far as it can go, I'm a fan of the rosewell Green series, they've never let me down in the 60 builds they've been in by me
Asus is a really good brand and for about the same price as your other board, they also OC nice too
doubled the HDD space and it seems to be cheaper without even touching a rebate
my favourite monitor is the Acer S230HL, LED backlit, 1920x1080p and its is pretty thin the only down side is that they cost about $140, i got my two from walmart but i think i could find them on newegg
