Build with Graphite 380T
I am saving up money now, it should be ready by September. By that time the Corsair Graphite 380T should be out (it's the mini ITX one).
http://pcpartpicker.com/user/fish20/saved/Rw97YJ
This is my first build BTW. I need some help to see if there is a better configuration.
Budget is $1300. Including a keyboard.
I'm saving for a 380T myself! But i have a few suggestions for you:
1. Why not use a 4670K, because the new socket in september is frankly a now-brainer. And with that Cooler Master cooler you can get some extra horse power out of it for free!
2. Also search for a ASUS or MSI or Gigabyte Z97 motherboard, so the processor would work.
3. You have chosen 8 GB 1333Mhz RAM, maybe chose for 1600Mhz and if you have the budget go for 16 GB for more future-proofing.
4. The Mushkin SSD is in my oppinion not a good choise. A better one is the Samsung 840 Evo 240 GB.
5. EVGA videocard + Asus motherboard is not a bad choice. But the best is matching the Motherboard manufacturer with the Videocard manufacturer for best compatibility and customizability.
But all with all a great build, and hope the 380T will be available soon!
http://pcpartpicker.com/p/K3wBhM
I could cut another $16, but I don't want to...
And yes, the Asus card fits, "up to 290mm" It's 287.02mm...
Drool.... Whatcha gon do with that big fat ITX?
wiggle wiggle wiggle ;P
looks like a great build.
