Build using my old GTX 650
My brother asked me to build him a computer for gaming around the £600 area, Thing is i wanna save him some money by using my GTX 650 that i dont use anymore since i upgraded a couple weeks back, So what would you recomend that could really get the most out of this card at this price range? Intel? Amd? Would be really helpful if you guys could help me out.
What games does he play?
does he need an os?
http://pcpartpicker.com/uk/p/twNe
Here is a build without the OS.
I went with the 2500K because it for some reason was cheaper than the 2500. Also if you want a cheaper build i would go with the fx-6300 or if you want an even cheaper build go with the fx-4300. They both do very good in gaming. If you decide to change to AMD though, i would also change the PSU to 600w or even 650w if it's going to be upgraded in the future.
At that price its a steal.
awesome thanks for the help guys seems like an awesome build, and i can get the OS off my college for a discounted price so its all good
and he would be playing things like team fortress 2 and battlefield off steam so yeah sounds pretty solid
thanks
