So I've been thinking about upgrading my current build, mostly because my Q6600 @ Stock is running near 60 C on IDLE, and I'm using a pretty shitty motherboard coupled with old DDR2 RAM. The bolded text is the upgrades. My upgraded build will look like this:
- CPU: AMD FX-6300 ~ $130
- CPU Cooler: Cooler Master Hyper212+ ~$30
- GPU: ASUS DIRECTCUII GTX560 TOP
- Motherboard: ASRock 970Extreme3 ~$75
- RAM: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600MHz ~ $60
- PSU: Enermax NAXN 82+ 550W 80 Plus Bronze ~$55
- Case: Antec NSK4480
Is this a reasonable upgrade or will the GTX 560 bottleneck the FX-6300? I am looking to overclock slightly on this build, the upgrade will cost about ~350 and I wanna stay in about that range. Any suggestions?
