I'm looking for the quietest GTX 770 with 4GB for my build upgrade this year. No more than $420 please. This http://pcpartpicker.com/b/Cj2 is my current build before the upgrades. I would also like to find a great Bluetooth connectivity device(add-on or USB). I would like to find some of the best 8GB 1866 low profile RAM also. Under $90 that will fit under my Hyper 212 EVO. Thanks in advanced!!
Your ram is fine as going up to 1866 will make next to no increase in general performance.
What I'd do with that budget (420 + 90) is sell the 7950 (for a shit load as miners will pay big $$$ for it) Also sell off that psu. So then you'll have about $850 or more to spend. - grab this>>
http://pcpartpicker.com/parts/partlist/ - few dollars more than the budget but will be very cool
psu will allow for a 2nd 780 later on. + 2 more monitors for some fun like this >> https://www.youtube.com/watch?v=eY3Kn1fGGTI
In regards to ram for your build. I personally am running something pretty close to the same thing. I find that the difference between 1600 ram and 2133 ram to be immediately noticeable. Far snappier system performance.
Can you post the part list again? The one you posted me just goes back to my own. I'm not really looking to SLI simply because there is no point in it. That, in my opinion, is simply for hardcore enthusiasts. I'm just looking for a 770 to Max out on Battlefield 4, Saints Row 4, NBA 2k14, and Minecraft as well as run the server for it. I will be making videos and a few montages for youtube. And again for everyone else also my current setup is http://pcpartpicker.com/b/Cj2 Nice money management solution by the way. I didn't even realize the prices of the 7950 skyrocketed from when I bought mine. I bought mine for $250 on Newegg with a promo.
here it is again. http://pcpartpicker.com/user/deejeta/saved/3snC
So i take it that you recommend Gigabyte over Asus?
Its a very debatable subject, for some benching / specific applications yes there is a small noticeable difference. For gaming its a no brainer, there is no point in spending up big upgrading (current ram prices) to gain the extra 1-2 fps. The only valid case for high speed ram is for APU's.
I have 2133 ram and I see very little if any difference in gaming performance vs if I have it at 1600.
http://www.anandtech.com/show/4503/sandy-bridge-memory-scaling-choosing-the-best-ddr3/6 &
http://www.tomshardware.com/reviews/bulldozer-ddr3-overclocking,3209-13.html
Wasnt really talking about gaming performance. Just overall system response. Too me its very noticeable going from 1600 to 2133. As far as gaming wise goes i agree.
well for a 770 with 4gb and quiet= ASUS gtx 770 $379 http://www.newegg.com/Product/Product.aspx?Item=N82E16814121837
If you manage your money well by selling the 7950, and not getting a 780...but getting the 770, you can get like an H100i and sell your Hyper 212 and not have to search for low profile ram... and if your motherboard supports 2133 memory then go ahead and get it instead of 1866, the price difference really isn't that large, if at all on some models.
Oh yeah and you can get some money by selling your mushkin 1600 ram. I found this 2400mhz memory for the same price as the 2133 here only $79 and I think it is low profile anyways... http://www.newegg.com/Product/Product.aspx?Item=N82E16820231665&clickid=WaGR3XRbG1mJSwnT0u0-ZSZCUkT1%3Ai2fNVOhU80&iradid=97618&ircid=2106&irpid=79301&nm_mc=AFC-IR&cm_mmc=AFC-IR-_-na-_-na-_-na
Faster is better.. right? lol
I just like their warranty mainly.
i think im going to go for the ASUS GTX 770 but i still need to know about the Bluetooth connectivity device(add-on or USB).
Do i have to change the liquids in the H100i?
Asus all day everyday lololol
Here is a bluetooth adapter.. just google search for one you like.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833320166
Yeah I bought the 2gb the other day. I love the fact that it has a custome PCB, a backplate, and high quality components and a 3 yr warranty doesn't hurt.
Thanks
no
great thanks
Your welcome. Good luck on the upgrade.
No. The H100i is completely closed loop. Don't quote me, but when I was researching it I think I heard or read that Corsair predicts 10 years or something ridiculous.
