Hey guys, just a quick one really, I was wondering if anyone could provide some input, I’m thinking on building a pretty small ITX/SFX system. I’d like to start by stating the following:
- I can’t stand RGB.
- I’d rather not have glass side pannels.
Now that we’ve got that outta the way, I’d like to start by stating that I’m thinking on using the Fractal Design Era case. What’s your input?
Of course, I’ve watched the L1 review in the case, thank you for that @wendell!
I’m currently using the good ol’ Phanteks Enthoo Evolv ITX case, but I’m looking to go smaller. I would go as small as the Dan A4, however, having built in the RVZ02 & monitored temps extensively, I can honestly say that I’d be constantly paranoid about the temps in such a small case.
I’d like to state that of all the things that I’d worry about, it would be the temps on the SSD’s, in the RVZ02, while it’s a pretty cool case & I love how much stuff you can fit in there, etc. It did basically fry my 2.5" SSD’s, the heat from the GPU was essentially just radiating onto the panel where the SSD’s attach to, I saw my SSD’s get into the 70’s while gaming. Hence why I decided to shift to the Enthoo Evolv.
I was just wondering if anyone has built in this case & had similar issues to what I had with the RVZ02?
Having done research around what I could get, I’d like to state that I’m not trying to get the best bang for my buck or anything like that, I’m just looking for a great power house in a very small form factor. This setup will primarily be used as a workstation rather than a gaming machine, at most I’m a casual gamer really, although I do like to play at 1440p goodness!
I’d like to clarify that I wouldn’t bother with those exact specs, they’re only there to give you guys an idea, in reality, I think I’d probably go for something a little different. I may end up waiting until the next gen of GPU’s hit the market, since Intel’s 10th gen CPU’s are out, I’m sure y’get my point, it would be a bit silly to update my build right now.
So without rambling on too much more, let me know what you guys think of that build? - Can you foresee any issues? Have you done a similar build? Any gotchas?
… It doesn’t have to be mechanical, I’m currently using a wireless keyboard, the Logitech K780, long story short, I need a Bluetooth connected keyboard & mouse, it’s a long story, work related, but thankfully it’s a pretty decent keyboard, although I am tempted to treat myself to the MX Keys.
