Build http://pcpartpicker.com/p/10bcO
If i were to build this computer about how much will my power bill go up because of it? of course it wont be full load 24/7 but if i kept it on 24/7 how much will it cost?
Not very much pc's now are very power efficent when at idle. If you are looking for the best power savings I would look at an intel cpu but at idle the difference between amd and intel is small.
Yeah thanks i was thinking about going intel but AMD is great for keeping your budget but i could go with the 3570k and still stay around my budget.
