Build PC for gaming / streaming
Hey guys , i am new to this forum and by this way i would like to salute you all. I hope that my english is understable.
I would like to buy a new pc for gaming and streaming.Most of the time i play Fifa 13 and Dota 2.
I want to stream at 1080p maximum ... i accept 720p maximum too ... and i can play the games in medium quality too.I also would like to add that my budget it's not very high, so if u guys would love to help me with a build i will be gratefull.
Thx and have a great day.
P.S.: I've forgot that i don't need a HDD , mouse , keyboard , screen( monitor ) or mouse pad, since i have them already
How much money is 'not very high'?
Don't know an exact price, i guess the cheapest for what i need to do.
Bump
Well you can do alright off of anywhere, we really need a price range. 500-2000 give a number.
hmmm ok i can go 400 - 600 $. just waiting for ur opinions guys.
[url=http://pcpartpicker.com/p/EJVB]PCPartPicker part list[/url]
[url=http://pcpartpicker.com/p/EJVB/by_merchant/]Price breakdown by merchant[/url]
[url=http://pcpartpicker.com/p/EJVB/benchmarks/]Benchmarks[/url]
  • [b]CPU:[/b] [url=http://pcpartpicker.com/part/amd-cpu-fd6300wmhkbox]AMD FX-6300 3.5GHz 6-Core Processor[/url] ($119.99 @ Microcenter)
  • [b]Motherboard:[/b] [url=http://pcpartpicker.com/part/asus-motherboard-m5a97ler20]Asus M5A97 LE R2.0 ATX AM3+ Motherboard[/url] ($74.99 @ Newegg)
  • [b]Memory:[/b] [url=http://pcpartpicker.com/part/gskill-memory-f31600c11s8gnt]G.Skill Value 8GB (1 x 8GB) DDR3-1600 Memory[/url] ($29.98 @ Outlet PC)
  • [b]Storage:[/b] [url=http://pcpartpicker.com/part/toshiba-internal-hard-drive-dt01aca050]Toshiba 500GB 3.5" 7200RPM Internal Hard Drive[/url] ($55.98 @ Outlet PC)
  • [b]Video Card:[/b] [url=http://pcpartpicker.com/part/powercolor-video-card-ax78702gbd52dhppv3e]PowerColor Radeon HD 7870 XT 2GB Video Card[/url] ($208.79 @ Newegg)
  • [b]Case:[/b] [url=http://pcpartpicker.com/part/athena-power-case-cagsb01da]Athena Power CA-GSB01DA (Black) ATX Mid Tower Case[/url] ($30.98 @ Newegg)
  • [b]Power Supply:[/b] [url=http://pcpartpicker.com/part/corsair-power-supply-cx500]Corsair Builder 500W 80 PLUS Bronze Certified ATX12V Power Supply[/url] ($49.99 @ Newegg)
  • [b]Total:[/b] $570.70
[i](Prices include shipping, taxes, and discounts when available.)[/i]
[i](Generated by PCPartPicker 2013-02-20 09:22 EST-0500)[/i]
THx a lot Andrew for this, i'll be waiting more offers, but again, thx a lot !
You really wont be streaming a whole lot with this.... might wanna put more money in the CPU.
Get a capture card so you can stream at higher FPS and it woun't take as big of a tole on your CPU
Ideally, this is what you would want for your needs: http://pcpartpicker.com/p/ELzC
Why would you go 400 over?
IMO thats a waste of time you could say that in every build.
You're complaining about a rather high performing 6 core cpu?  Really?  the only place you can go from there on this one is an 8 core 8320 or 8350.   Logan did a nice vid about how well AMD FX chips can multitask streaming and gaming.  His whole 8350 vs i5/i7 video was based on the results while streaming... and the FX 6300 isn't far off the pace of the 8350.  He'd probably want to put something into cpu cooling.  but that's neither here nor there.  He wanted something in the 400-600 range.. that's about the most capable machine you can build for that budget.  Show me something better then that.  because sticking either of those two chips... or an intel into this type of build will push us over the OP's $600 cap... by a lot in some cases.
This is actually my recommendation as well. If you're on a  budget it's going to cost you more for the hardware to stream through the host pc rather than a pc that can run games at a sexy resolution and then stream through a dedicated card. Also at $600 a gaming rig and a "streaming" rig are virtually the same thing.
IMO the sweet spot for a dedicated gaming pc is $700-800,if you put the money where it matters you'll be able to run games at ultra no problem. At $600 it makes more sense to build as close as you can to a $700/800 build and then put $100-150 into a cap card.
i'll take it as a joke ... its not 400 - 600 range ... and if u have read my initial post you could see that i don't need any HDD ... thx anyway for your time
I do have 1 question for you mate ... if i have:
Dual Core 2 Duo @ 2.70 Ghz.
4 Giga Ram
Nvidia Geforfe Gt9600 512 MB
will i be able ever to stream at 720 maximum with a capture card ?!
Thx a lot for all the guys that answered my thread ... i will take your thoughts in consideration.
4 Giga Ram
a capture card will offload a lot of the GPU strain from streaming.  Enough you'd probably only see a few frames less per second.  Even in 720p
