ok well im building a computer for my aunt and alot of crap went wrong and i had to scrap her old build and start over so it needed to be cheap so i scooped up a A-6 5400k and got a motherboard for dirt cheap as a combo deal. In my build i have a A10-6800k. The motherboard that i got for dirt cheap is much better than i have in my build so i decided that i would just take the one i got for dirt cheap and give her mine (since i do gaming and she just uses the internet). i know that both chips run on FM2 chipset so this should work. but her computer post's but no splash screen comes up at all it just stays a black screen so im confuzzled (i know that it posts because of the speaker on the board beaps 4 times which means it posts right?). And mine dosent even do anything (it has the new motherboard in it) i know the board isent doa because every once in a while when i turn the power supply off and back on everything starts up then turns off. The new motherboard is a MSI FM2-A85xa-g43(http://www.newegg.com/Product/Product.aspx?Item=N82E16813130709&nm_mc=KNC-GoogleKWLess&cm_mmc=KNC-GoogleKWLess-_-Motherboards%20-%20AMD-_-MSI-_-13130709&gclid=CKme8caE97kCFapAMgodAB8AJQ&gclid=CKme8caE97kCFapAMgodAB8AJQ)(its 85 on newegg and i got it for 20!) and the old board is a MSI FM2-a75MA-E35(http://www.newegg.com/Product/Product.aspx?Item=N82E16813130662) the build with the older motherboard worked 100% before i switched it out. I havent switched it back but i honestly dont want to unscrew it and whatnot lol enless i need too.
IM sorry for textwall
thanks in advance for you help if you need any additional info just let me know
okay well my computer is solved :P idk even what i did but it just turned on, on one of my attempts rofl. But hers still dosent work. i tried resetting the battery but that dident help. i dont understand this problem at all its like it posts and starts but the screen that pops up is just black. i can tell that there is just a black screen because my monitor goes into sleep mode instantly if there not video being played through it...
?? the old cpu was just in it. like 10 seconds befor i put the new one in the bios was up to date because i was literally using in 30 seconds before i put it in the new build.
well now that my computer is fixed its just my aunts.... there is a correction that i need to make when i turn it on it beeps 5 times. and no splash screen comes up nor the bios or anything of the likes its just a black screen
