This build is a work in progress as of 28/06/2020, post will be edited further.
So the goal here is pretty straight forward:
I’m building a GPU loop in a Silverstone FT03-mini. No radiators outside the case, all 4 panels on, no vent holes or dremeling allowed on the sides. Bulkhead dremeling to pass tubing is OK. Basically it needs to look like this:
In this tiny thing is an i7 8700k at 4.9 on a Noctua L9x65, Gigabyte’s Z370N Wifi, a 16gb kit of DDR4 2600, a 1TB Samsung 970 Evo, an MSI 5700XT MECH OC, and a Seasonic SGX-650 SFX power supply.
My prime reason for water cooling is that MSI shipped most models of the 5700XT with defective coolers, undersized thermal pads for the memory, thermal pads that don’t contact the heatsink and some that are utterly useless. Since every RMA department is overwhelmed right now and I’m certainly not waiting 2 months for a replacement card, it looked like a fantastic opportunity to spend 75% of the price I paid for the card in water cooling parts.
- Alphacool Eisblock Aurora Plexi GPX-A Radeon 5600/5700 XT Pulse / Mech & Evoke
- 11/8mm (8x1,5mm) compression fitting outer thread 1/4 - black nickel
- tubing PVC 11/8mm (5/16"ID) clear
- Alphacool DC-LT 3600 ceramic - 12V DC - pump - bulk version
- Alphacool Eisstation 40 DC-LT - reservoir
- Alphacool NexXxoS UT60 Full Copper 120mm radiator
I also have 90 degree fittings, a 140mm 3000rpm industrial fan from Noctua, some sleeved cables and a ball valve on the way, and I’m debating whether or not I should get quick disconnect valves.
For now I have fitted the components I have together as a proof of concept before starting to think about what to do next. Good news though, the temperatures I had with the 5700XT MECH OC’s defective cooler have gone down by a whopping 40C. GPU hotspot is at 71C under full load at 28C ambiant.
Next steps:
Since the motherboard is mounted 90 degrees offset, and the “back I/O” is in fact on top, the top panel I/O is useless. I decided I was getting rid of that. 4 screws, and it’ll be out. I decided to repurpose 2 industrial switches with orange LEDs as my power and reset buttons.
As you can see I adapted the JST connectors on the buttons to the 1mm pogo pins we all know and hate. Not my best soldering job, but I couldn’t dump heat without melting the plastic and it made a mess, so yea you piss with the cock you got.
So next up, meaning as soon as the fittings get here, the top panel I/O is coming out and the pump and reservoir are getting relocated up top. Might need some bulkhead fittings and dremeling through the top to make it look clean, but we’ll see.
I’ll keep y’all posted.
