Awesome looking build sir!! I hope you have better luck with that 10GB card than I did. I have the same card, and I have had NO luck with that thing, on two different motherboards, including my C7H, which looks almost exactly like yours.
NICE -
I’m a sucker for the Fractal R6/S2 series chassis. You can do most anything with’em.
@Marten Thanks!
@Bartacus They’ve worked flawlessly in the past in two of my QNAPs, but it was a pain getting everything smooth in Windows.
@Delta9K Yes! I have always wanted one, but told myself only if I ever did water. Glad I picked this for my first loop. There’s just endless amounts of room to work.
@Zszywany Thank you!
1 week later and the air bubbles are finally all bled out. The XE rad trapped so much more air than the PE.
Check out the Optimus parts they look pretty slick
Yeah. I wanted to use Optimus for my incoming TR3 build, buuuuuuuuuut their TR and 2080 Ti blocks are both pre-order status. Sigh.
Contact them for eta, I can lend you my ek TR block if you want a place holder. Nickel / plexy
