Build Help!
So here in the next few months im planning on upgrading my case for my newest build. This build is a red and black themed build and i need a full tower case, and i'd like most or all of the following:
Good cooling
Cable management
cpu retention hole
black and red
PAINTED INTEREIOR!
sub $200 would be GREAT!
any thoughts would help tons :D
HAF X look know further its a black case and red leds:D amazing cable managment:D 4 200mm secnds and 1 230mm fan! black interior unlock the HAF 932 and its a HUGE case ur going to run outta of things to put into it before u run out of room so stick with this!
What about the Red version of the NZXT Phantom?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146066&cm_re=NZXT_Phantom-_-11-146-066-_-Product
Corsair 650D, paint it and mod it to your liking.
I've found the perfect match, the Silverstone FT02B-WRI, although it's gone everywhere and no longer in production. The NZXT Phantom is your last option.
Definitely grab an nzxt phantom. I love mine. Plus some minor modding will get you a sexy mesh window.
[IMG]http://i133.photobucket.com/albums/q76/bulletproof1029/2011-04-07073225.jpg[/IMG]
^That's a pretty awesome mod. I'm not gonna lie.
A friend of mine has this same case.. and it is amazing. We call it the stormtrooper. The only thing that sucks about is that it only has two USB ports in the front.
