Build Help
In short, i'm trying to decide whether i should add a second GTX 650ti Boost from EVGA or should i go and get a better single card gpu from AMD? My budget isn't really set, need to save up a little more money before i can do anything but want to make a decision before i can do anything.
Current set up:
Mobo: Asus M5A99X EVO R2.0 (Socket 942)
Cpu: AMD FX-8350
Cooler: Cooler master hyper 212 evo
Ram: Kingston Genesis 8gb 1600mHz
Gpu: EVGA Geforce GTX 650ti Boost
Psu: Antec 600w
Case: Antec six hundred v2
I'd suggest a new single GPU:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814125439&AID=10657534&PID=3938566&SID=&nm_mc=AFC-C8junctionCA
