Build Help
I created a list of parts im looking to use in my budget LAN build
Im not sure however if all of the parts will work well together
  • Case-BitFenix Prodogy
  • Motho- AsRock FM2A75M-DGS
  • CPU- AMD A10-5800K Trinity 3.8GHz
  • RAM-  G.SKILL Ares Series 8GB (2 x 4GB)
  • PSU- CORSAIR Builder Series CX430 430W
  • HardDrive- Hitachi GST Deskstar 7K1000.D 1TB
Also am i forgetting any components because this is my first build im not sure what is needed to get the computer up and running I already have the os i just need a list of the small things that I need
http://pcpartpicker.com/p/rSGN I put that together and it should work, if you have any more specific quetions, just ask. PCpartpicker is a good resource to use though.
