first off HI :D im new to tek syndacte forums and figured this would be the best place to get reccomendation and pointed in the right direction
so im finally in a position where I can spend a reasonalbe amount of money on a high end gaming rig and wondered what would you guys recommend, I have not kept up with the market as much as should have but did not expect to be in a position to get more or less what ever I want that being said I want the best cost to performance ratio possible. I am not 100% sure with what I should go with right now there are just so many possiblites and bottle necks that I am probably not aware of, I would appreciate it greatly if anyone could help me make a part list for the optimal ultimate gaming rig, I have some parts from an old build that are still usable and a general idea of what I would like to get and would like to know what you would change :) this will be used many for 1080p gaming on a single monitor right now BUT I do want to upgrade my display situation asap to higher resolution setup be that a single monitor like a cat leap or a 3x1080p setup, I do have a fair amount of building experience but not within the last few years due to a busy schedule and lack of funds to even bother but now that completely changed and its time to get back on the horse!
I would also like to say thank you in advance for anyone who has the time to help me out :D
what I do have:
- 2x 1.5tb seagate barracuda HDDs
- 1x samsung 830 128gb SSD
- ultra x3 650watt PSU(not sure if this will be adaquet or not got it on sale a couple years ago before I knew I could do better)
- windows 7 ultimate 64bit
what I was considering
- fractal design define r4 chasis
- asus sabertooth z77 LGA 1155 mobo
- not sure what kind of ram to go with there are SO MANY OPTIONS
- gtx 680 (only because I dont know much about ati cards ive never had one but would not be opposed to buying one)
- probably a seasonic psu
- as far as cooling goes I will be putting in a custom loop then over clock the pants off of it
