Hey everyone,
I am planning on using the computer for gaming (mmo, rts, moba, fps), video capturing while I game, minor photo editing. I would also like the computer to easily handle me gaming, while I stream video, music, and run multiple tabs on all of the screens.
Below is what I have put together so far, without the monitors.
http://pcpartpicker.com/user/Jala47/saved/HwHnTW
I am wanting to setup three monitors. I have read up that the 970 GTX will handle three monitors, but is it as efficient as running two of them in SLI, or running two lesser cards in SLI?
These are the monitors I have found so far, though I'm still looking if anyone has suggestions. I want something around 24”-27” that can be mountable.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236288
http://www.newegg.com/Product/Product.aspx?Item=N82E16824014378
I have been looking up on monitor arm mounts, any experience or recommendations on them would be appreciated.
I am also looking at getting a mechanical keyboard as well, could use some recommendations on those too since I only have experience with basic keyboards.
This as well as other tips on the build itself as a whole would be appreciated, thanks!
TL;DR What 3 monitors, and GPU(s) do you recommend?
*Edited: Updated the pcpartpicker list
