So in May/June I should be finally building my desktop. I have gotten together a list of parts that is close to my budget. If anyone has some suggestions on different parts that could save a few bucks I would appreciate it. Especially the GPU I am not an intense gamer so don't need the best of the best but would like something that I could play Hearts of Iron 3, Or maybe sim city and minecraft with some cool shader packs on high level while it is still quiet, and with a bit of room in case there is a new game that comes out that catches my interest.
For the ram I am getting a compatibility problem according to pcpartpicker so any suggestion on a reliable set would be awesome or if it's not a real issues that could be solved with a bit of overclocking let me know.
"Kingston Blu 8GB (2 x 4GB) DDR3-1600 Memory operating voltage of 1.65V exceeds the Intel Haswell CPU recommended maximum of 1.5V+5% (1.575V). This memory module may run at a reduced clock rate to meet the 1.5V voltage recommendation, or may require running at a voltage greater than the Intel recommended maximum."
Prices are Canadian. Although I am considering mailing it all to a friends house in the states to save a few hundred bucks. Thanks in advance for the comments have a good day.
http://ca.pcpartpicker.com/p/3v37m
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor $238.98
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler $31.79
Motherboard: Asus Maximus VI Gene Micro ATX LGA1150 Motherboard $223.97
Memory: Kingston Blu 8GB (2 x 4GB) DDR3-1600 Memory $79.99
Storage: Kingston SSDNow V300 Series 240GB 2.5" Solid State Disk $129.75
Video Card: EVGA GeForce GTX 760 2GB Video Card $299.99
Case: Fractal Design Arc Mini R2 MicroATX Mini Tower Case $108.00
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply $59.98
Optical Drive: Asus BC-12B1ST/BLK/B/AS Blu-Ray Reader, DVD/CD Writer $59.93
Total: $1232.38
