Alright, I've been wanting to upgrade my laptop for a while, and now I'm ready to make the jump, but I need some advice My main work uses are Autodesk Inventor for some product design, no stress tests or analysis work to speak of, but I'd also like to get into animation and video editing encoding. Also it has to be able to have two monitors to begin with and be upgradable to four. As far as games are concerned, it should be able to run CS:GO at >100 FPS, and BF4, Titanfall and Starcraft at ~60.
Ideally, the main focus for components should be upgradability. A full ATX mobo is a must. No need to have too many SATA Ports as I should have a NAS before I have too much data, but onboard RAID is still a good idea. I won't be overclocking or I'll be making the case myself,(will post more on this later) so no need to worry about that. The power supply should probably modular, and > 750 Watts. The rest ill leave up to the forum with this and some other general information as a base. The budget for the computer internals is probably around $650, but That can be increased and I can save for it for a bit longer. Not yet released components can be added in if you think they will make a considerable difference. I wont be building this until the end of the summer or later if need be.
Thanks in advance for all the help ladies and gents of Tek.
Other info:
No need to worry about a mouse or keyboard
I'm handling the monitor(s)
I prefer AMD, but I could be swayed otherwise.
