Build For A Server
Here are the parts that I have put together in a cart. Does this look well enough to run a server
Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813135315
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811165491R
Memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820239434
Add-on card: http://www.newegg.com/Product/Product.aspx?Item=N82E16833106033
Processor: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103953
Optical Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822148766
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817338053
Well the motherboard you chose, wouldnt fit the case.. The case was for Mini-itx. If you want a mini-itx case (small case) then I would recommend swapping in these parts.
http://pcpartpicker.com/p/19F2m
Thats a good mini-itx motherboard, and they don't come too much cheaper than that. (about $85+)
The HDD I threw in there is designed to run 24/7 so its good for a server and isnt too much more. The processor I chose is a little more, but has an integrated video card, and the ram I included is low voltage and cheaper. so saves on your energy bill a little and saves money up front.
Now if you are looking for something cheap, then how about this?
http://pcpartpicker.com/p/19FcU
These are all quality parts, and if you want a smaller case, they are out there, but a bit more expensive.
