Friend just wants to know if this all works together, because im still learning alot i wanted to see if the pros can double check :) thanks.
http://pcpartpicker.com/p/2gbiE
It'll work, but I wouldn't recommend it.
http://pcpartpicker.com/p/2gbB5
If this is just for gaming, I'd go with Warpig's build. 8GB is fine for gaming. My own build rarely goes over 6.5gbs of usage. 8 cores with that 8320 will be helpful in future games like BF4.
Noctua coolers are some of the best air coolers out there, even though they aren't the best looking.
And unless you have some super large budget that supports 780ti SLI or something, I'd suggest getting the largest single-GPU card config. There won't be any microstuttering and will have a nicer performance overall.
