Build Compatibility
AMD x4 A10-5800K Quad Core 3.8Ghz/4M/100W FM2 CPU ADVAD580KWOHJBOX Integrated Radeon HD7660D
GIGABYTE GA-F2A75M-D3H A75 FM2 4xDDR3 SATA3 USB3 DVI HDMI RAID mATX Motherboard
Patriot Viper Xtreme Div.2 PXD38G1866ELK 8G Kit(4Gx2
Thermaltake TR-500PCAU TR2 500Watt. 80+ Bronze PSU
NZXT Phantom 410 CA-PH410-W1 White Steel / Plastic ATX Mid Tower Computer Case
I already have a harddrive.
Create the build in pcpartspicker, it will tell you if it's compatible.
