Build almost done which 140mm fans should I get? Add your 2 cents
I already have 3 Noctua's and hate the color plus have been told they suck for rads and are super over priced. SO I need a total of 8 fans and I'm down to these three please help me pick one and recommend your own if you want just not into L.E.D.s unless they are purple and 4 will be plugged into my Kraken and 4 into my fan controllor.
Here is my build upgrade part list I allready have the FX-8350 and the Asus Sabertooth MB and Corsair 750D case.
http://pcpartpicker.com/user/StaticNoize/saved/28q8TW
Aerocool
Bitfenix
Noctua Industrial
Wish these existed when I was building my PC
I want to get the Ek Vardar really bad more than anything else but only come in 120mm and are rumored to come out in 140mm but no rumor of release date. same with the Gentle Typhoon really like those too. Two of my fans now are the ones that came with the Define R4 and they aren't bad at all I just want matching fans if I'm already spending over $3,000 on my upgrade. I just know that Fractal are known for cases so never really checked out their fans. I will check out the video can you add your 2cents about the ones I picked.
Ive also got 3 Thermal Right 140mm fans that mount in a 120mm fan slot I hated that when I got them because can't mount them but they are awesome.
You want high static pressure for mounting on a rad right? IDK I just want the best performance for my 4 fans for the rad and then 2 intakes and 2 exhausting on top of each other actually works great. That being said I'm willing to get 2 different kinds for best performance for my rad and intake and exhaust.
(also the define R4 was my favorite case but you can't mount the Kraken in the top in a push pull config. The Corsair Obsidian 750D is my new fav just wish it had sound dampening, Corsair told my the rad in push pull wouldn't fit in the top and it does no problem only case that is black and simple and sexy that I could do this. I was going to get the 800D or 900 which ever the bigger one it is but for $300 just wasn't interested. My only complaint about the 750D is the metal under the motherboard flexes I noticed this when I opened the case to move my hardware into it the Define R4's quality is superior to Corsair.
It'd be up to you really, though I think the idea of being able to mount the venturi fans as 120mm
Not a fan of 120mm fans can't mount them on my rad unless I fabricated adapter brackets but even then 120mm don't move as much as 140mm. I already watched that video it was next on the playlist. OF the 3 fans I picked which one would you go with????
Venturi probably, but that's because like I said, the option to run them as 120mm fans is nice to have.
Ugh.... for like the third time.....I got that's what you recommend I want to know which one you would go with out of the 3 links I posted at the top it was my original question.
Whatever preforms the best naturally.
The aero cool ones seem nice.
I love the way they look they are the 2nd most expensive and have a max of 1,500 rpms and I have never heard of them but they have a good review on Amazon, but The Bitfenix Ive heard really good things about and they are the cheapest but only have a max of 1,200 rpms, the Noctua is the most commonly known and everyone swears by them but they are the most expensive and had it recently explained to me they aren't good for Rads and are over priced and aren't worth it at all and they have a max of 2,000 rpms.
I don't know what to do 120mm is not an option like I said they wont mount on my rad and to mount them as intakes on my case I have to get special brackets.
