Hi Boys and Girls,
I am looking to build a PC. I need it to be in a small form factor for travel reasons. Having said that I also want it to be overkill as I have a beast laptop now, so I have to be able to spank it to make it worth while. Hence the SLI config in the proposed build. I had previously thought SLI in the case was impossible without taking out the bottom internal fan. However after seeing this video build it looks like a possibility although very tight if it can in fact fit at all.
I have also gone with a LGA2011 MB for upgradability down the road, should I get restless (you know how it is)
Case Silverstone FT03B MicroATX Mini Tower
CPU Intel Core i7-4820K 3.7GHz Quad-Core
CPU Cooler Corsair H80i 77.0 CFM Liquid
Motherboard Asus Rampage IV Gene Micro ATX LGA2011
Memory Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-2133
2 x Video Card SLI EVGA GeForce GTX 780 3GB
I'd love to hear you're feedback on this build and any suggestions you might have.
My main concern is if the bottom internal fan needs to come out I am really stuck with terrible airflow. So I guess my main questions are...
1) do you think both cards will fit keeping this bottom internal fan
if not..
2) if it needed to be taken out, best cooling solution.
Thanks in advance :D
