Build a pc $600-$800
With the information in the title i would need:
-windows 7 64-bit
-500GB harddrive @7200rmp
-will be buying parts in america
-microphoned headset
-CPU
-mini-atx case with front USB 3.0 ports and easy to carry
-mother board with onboard WIFI adapter
-DDR3 RAM
-80+ bronze PSU
-Graphics card
All of this for $800? not likely but ill try.
http://pcpartpicker.com/p/TGco
Best I could do is about $850 without headset, you'll have to choose that. Don't worry about the compadibility issues, the motherboard will fit in the case.
OK let me give it a try
Cpu Amd 8 core 8350-$199.99- Heres a intel one if you dont like amd -Cpu-$219.99-
Mobo-$54.99- If you go intel-Mobo-$52.99
Case-$34.99-
HDD-$59.99-
PCI Wifi Adapter-$26.99-
PSU-$54.99-
Ram-$60.99-
Windows 7 64bit-$99.99-
Headset with mic-$59.99-
GPU-$164.99- Comes with Free FC 3 Blood Dragon, Bioshock & Tomb Raider
That comes to $817.90 if intel $835.90 with $100 worth of free games. Every is exactly as you requested.
You did not mention any thing about a dvd drive you will need one if you dont have one it will cost you an extra $15 or so.
I hope this helped you.
[img]http://assets.vr-zone.net/8935/gallery/NZXT_Vulcan_06r.jpg[/img]
http://pcpartpicker.com/p/THIQ
CPU: AMD Phenom II X4 965 Black 3.4GHz Quad-Core Processor ($94.84 @ Amazon)
Motherboard: Asus M5A78L-M/USB3 Micro ATX AM3+ Motherboard ($83.98 @ Newegg)
Memory: Mushkin Essentials 8GB (2 x 4GB) DDR3-1600 Memory ($59.99 @ Newegg)
Storage: Hitachi 500GB 3.5" 7200RPM Internal Hard Drive ($56.98 @ Outlet PC)
Video Card: Asus Radeon HD 7870 GHz Edition 2GB Video Card ($238.98 @ SuperBiiz)
Wireless Network Adapter: Rosewill RNX-N150PCe 802.11b/g/n PCI-Express x1 Wi-Fi Adapter ($8.99 @ Newegg)
Case: NZXT Vulcan Black MicroATX Mid Tower Case ($69.98 @ Outlet PC)
Other: Syba CL-HUB20113 2 Port USB 3.0 for 3.5-Inch Front Panel with 19 Pin Header Cable ($15.00)
Other: Microsoft Windows 7 Home Premium SP1 64-bit ($60.00)
Other: CORSAIR Builder Series CX600 600W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply ($65.00)
Other: Rosewill RHTS-8206 USB Connector 5.1 Channel Vibration Gaming Headset ($50.00)
Total: $803.74
