This pc is for all you guys who want to get out of the console and play with the big boys pc gamers.
This build is the absolute entry level pc but it has a lot of upgrade possibilities.
To start it off the cpu is the A6-5400k 3.6 GHz FM2 CPU not the greatest apu out there but you can always upgrade to a A8 or A10 which would give you a vast performance upgrade. 49.99@Microcenter
For the motherboard we will be going with the MSI FM2-A75MA-E35 this motherboard gives you everything you need and nothing you don't it has 6 SATA 6 ports which is really nice also it supports up to 16Gb of DDR3-2133 memory which is really nice for this price 59.99@microcenter
For the HDD we will be using the Toshiba 7,200 RPM SATA 6 Hard Drive its cheap and the reviews about it seems very positive 49.99@microcenter
For the memory we will be going with the Corsair Vengeance 8GB DDR3-1866 2 X 4 GB sticks this ram is very high quality and this stuff is really really fast people use this ram in 1500 dollar builds a little bit pricey but worth it 74.99@microcenter
For the Psu we will be going with the Diablotek EL 400w psu people may say don't skimp on the psu but I have the same exact psu and I had it for 3 years and its still running strong also it comes with a 1 year warranty all for 14.99@microcenter
The DVD drive is a LG DVD burner its 15.99@microcenter hate optical drives we need flash everything
The case is the Diablotek Gamer Series Citadel ATX case its just a house for your machine for 10 dollars more you can get a way better case but we need every penny 21.99@microcenter
The total is $287 before tax.
Upgrade Possibilities:
SSD around 99 dollars
A10-5800k 100 dollars at microceter
80+ bronze psu around 40 dollars
Better case around 35 bucks for a decent case
