Buget build
Im looking for a decent build that fits the price of 600$ mostly for gaming web browsing.
http://pcpartpicker.com/p/3rkWFT
here you go, This will game in 1080P ultra settings in %90 of games right now. Though, The sacrifice for a skylake CPU was in the SSD ...you will want to save for a HDD that is at least one tb
I like ProSonicLive's build.
My only addition would be that you could possibly squeeze in a 250 GB SSD within your budget. Having just 120 can be a little rough.
Are we getting the d later ;)
Here's my vote... AMD build to beef up the GPU a level.
http://pcpartpicker.com/user/johnmatt112/saved/LtqZxr
(*there are promo codes and $90 worth of mail in rebates on this one too, which would get you sub $500, or you could throw in a nice 3TB HDD)
Oh the agony of brown PCB with 3 shades of blue accents on the motherboard, red memory amd red GPU... And the case have a window.. It's like beauty and the best, but the beauty is without makeup and the beast just woke up, so he is uglier than usual....
By the way, the best option is 4460 with some B97 or H97 or whatever mobo with 390... Or 380X... No need to go as low as FX 6300, nor to jump to the 6500 Skylake...
Just a thought...My X3 was on it's third motherboard when replaced. MB's die, Cpu's last forever
Yeah she wouldn't be pretty I guess... but when you're trying to come in so inexpensive I think it's best to go budget all around and dump as much as you can into a solid GPU
