Hi i was wondering if somebody could do me a budget watercooling setup for under £300.
I'm in the UK and i don't want anything imported from over sea's.
My current specs are:
Case: Fractal Arc Midi R2
CPU: AMD FX 6300
GPU: AMD Radeon 7850 - I want to upgrade to a 7970 soon so waterblocks for both please
Mobo: Gigabyte GA-990FX-UD5
RAM: Corsair Vengeance 8GB (2 x 4GB) DDR3-1866 - I don't want this watercooled but i thought the heatspreader's could be a problem
I would like a Blue colour scheme if any, thanks in advance - Rotating Camel
XSPC Raystorm D5 kits are good building blocks for adding more to the loop.
Once you have that when you want to water cool the GPU you just need to add the block and rad.
The XSPC 750 kits are good for just the CPU but you'll need a new pump to add more to the loop.
Have a look here for UK based retailers. I've used them both in the past with no problems.
http://www.watercoolinguk.co.uk/
http://specialtech.co.uk
i would personaly first invest in a better GPU like a Radeon R9-280X , but thats probably just me ☺
I have run the 750 with both gpu and cpu and it works well. Anything more than that and I'd get dual pumps.
+1
Also, not sure if worth water cooling a FX-6*** CPU?
But if you just GOTTA do it, I would start with an XSPC kit, usually get one for under $180 CAD.
