Budget PC build
I need feedback on some new PC parts I've ordered, it's a limited budget build, I need it just for gaming. my old one is just... well, old. I'd love to hear your thoughts, and suggestions for a case and fans (nothing too crazy).
Current PC...
My current PC
The parts I got:
AMD FX-8350 Eight Core 4.0GHz
Corsair Hydro H105 240mm
Asus SABERTOOTH 990FX R2
Corsair Vengeance Pro 2x8GB DDR3 1866MHz
EVGA GTX770 Dual ACX SuperClocked 2GB
Western Digital Caviar Blue 1TB
Corsair Force GS 128GB SSD
Corsair 750W Active PFC Modular 80+ Gold
very very solid build, have you bought the 16gb of ram? because it's fine to have 8gb unless you're doing video editing or streaming or rendering stuff.
Other than that its a very good build that has great overclocking and high performance gaming.
Great, thanks. about the ram, I'm kinda future proofing it, and I got a good deal.
I would recommend a M5A99FX Pro R.2.0 over a Sabertooth, had both and had better experience with the first.
I have a Sabertooth 990fx R2 and it works incredibly well for me. Never had any issues, auto overclocked my CPU to 4.3GHz which was plenty for me. Not saying Cathsy is invalid, I'm simply stating my experience.
I chose that MB because of the "TUF components" thing, and a lot of people have said the same thing as Boom. but the M5A99XF is a great choise too, it's almost the same as the Sabertooth, and a little cheaper.
I just have had better experience with it. I never used the auto overclock so im not sure about that. I know the M5 has a tougher VRM, my temps were much lower on the VRM on the M5 than the Saber tooth.
Lower temps are awesome, I'll look into it. thanks.
Sure. Not saying the Saber tooth is crap or anything, but I was able to get a higher overclock at a lower temperature than on the ST. FX overclock is usually limited by the VRM temps long before the CPU temps. =O
Will I need to update my BIOS for the 770 and the amd 8350?
You shouldn't have to update the BIOS/UEFI for any graphics card.  The sabertooth should be able to support the FX-8350 right off the bat as well.
Thanks.
Saber is a nice board almost up to 4.8 with push button overclocking.
