Budget PC build
Hello everyone I'm going to build my first PC and want to get some advice.
Sorry if I make some mistakes(english is not my first language and I'm just learning it at school).
So here's the build:
CPU: AMD Phenom II x4 955 Black Edition
MOBO: Gigabyte GA-78LMT-USB3
RAM: 4gb(2x2gb) of Patriot 1333mhz
GPU: I'm going to buy a graphics card when I get some more cash and time to play games.I think of buying an ASUS HD7770.
PSU: Corsair cx430(will 430w be enough for everything?)
CASE: Zalman z9 plus
Will all these parts work together?Thanks in advance!
theyll work togather but for like 5 bucks more you can get the 965 black, which will give you a bit more in performance. i have a simaler set up and 430w is enough. i kinda wish i bought a biger psu though for upgrading down the road. if you get a 650w or so you wont need to worry about upgrade options as much as i will have too. although my psu cost me 20 bucks so i could just buy a new one. lol
I wanted to get the 965 in the first place but then the shop where I'm going to buy all the components stopped selling them for some reason(I live in Lithuania and there's not a lot of shops to choose from and ordering from amazon costs more in the end) so I went with 955 instead.I might go with a 500w instead of 430w.
the 955 is still a a good chip and its more overclockable than the 965 but grab a 500w psu (80+) to be comfortable
Only one thing if youre getting this card http://www.newegg.com/Product/Product.aspx?Item=N82E16814121642 youll be fine because it has 2 fans 2Gb and it doesnt have menny complaints about it in the feedback there! Chek it out :)
