What do you thinl. mainly for 1080 gaming on high settings. any changes? different case? better psu? cheaper gpu? Phenom II? give me your thoughts(:
Thank you!!!
cooler master elite 430 (case) 37$
corsair cx 430 watt (psu) 45$
lite on drive 16$
cooler master hyper 212 (heatsink) 30$
corsair vengance blue 8gb (ram) 53$
seagate baracuda 7200rpm 500gb (hard drive) 50$
Gigabyte G8-970ADS3 AM3+ sata 6gb/s (motherboard) 80$
Amd Fx 4300 (cpu) 120$
Saphire radeon hd 7770 (gpu) 140$
Ya It looks good the fx 6300 can be had for the same price otherwise it looks good.
thx for the commented. really apreciated!
might need to go with higher W PSU because 7770 requires 450W minimum, so i would recommend at-least 500W. and also let us know your budget, so someone can help you build the PC!
the 7770 only has a tdp of around 100 watts. if you mean full system, then maybe. but the cx430 is a high end psu even though its only 430 watts. do you know of any cheaper psu's that are better suited. Also i know that my price is like 560 right now, but i want to get it to 500 if possible.
