I need help building a 500-600$ gaming pc that can play any game on medium to high settings. I have no idea what parts are good and what not. As of now i dont have any parts. This is also my first build/
This comes up to I think $650 but its worth the extra $50 I think
Includes a monitor and Win7
http://pcpartpicker.com/p/ICcv
http://pcpartpicker.com/p/IBUl
I will show you the fruits of my budgeting labour.
You can get a monitor and win7 after this build.
Or if you don't need win7/monitors use this.
http://pcpartpicker.com/p/IC2Z
http://pcpartpicker.com/p/ICN5
What about this?
Suggestion, get FX 6300 and you don't need a 2133mhz RAM so get 1600mhz...
Thanks
http://pcpartpicker.com/p/HYeo
This is quite good, the 650ti is a little bit better than the 7770, and the motherboard gives you plenty of upgrade path. It's a little bit on the pricey side, but I think it is worth it
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161406 - Radeon HD 7850 2gb 180 beats the GTX650ti 2gb Zotac 165
http://www.hwcompare.com/13797/geforce-gtx-650-ti-2gb-vs-radeon-hd-7850/
Anyway you should included tax rate of 8% inside the partpicker, I think that is the tax rate in USA for hardware... Right?
