Budget PC Build ~$500
How does this build look for a budget gaming PC?
CASE Antec VSK-4000E Mid-Tower ATX Case - $30
MOTHERBOARD Gigabyte 78LMT-USB3 AMD760G mATX - $50
PROCESSOR AMD FX-6300 Six Core Processor Socket AM3+ 3.5GHZ - $120
MEMORY G.SKILL Ripjaws F3-12800CL9D-4GBRL4GB 2X2GB DDR3 - $47
HARD DRIVE Seagate Barracuda 7200.12 500GB 3.5IN - $55
DISC DRIVE Samsung SH-224DB 24X SATA DVD - $24
POWER SUPPLY Thermaltake TR2 500W Power Supply - $43 VIDEO CARD EVGA GeForce GT 640 901MHZ 2GB 1782MHZ DDR3 - $115
This build was proposed by a friend of mine. I think the Ram should be increased and the graphics card...But I don't know a lot about Computer Hardware.
On a side note: Can anyone recommend a good headset for $60-70.
TBH, that looks pretty shitty.  Prices today are really high for computer parts :/
Incredibly weak GPU.  I would get something like this: http://pcpartpicker.com/p/2u36A
I got my Steelseries Siberia V2s on sale for $50.  I like em.
http://pcpartpicker.com/user/Skreedles/saved/3jPi
Updated.
I would get a better motherboard that actually has some cooling:
http://pcpartpicker.com/p/2uCFU
id grab a fx 4130 if you wanted to stay closer to your budget
FX-4130 is old bulldozer architecture.  I would recommend at least the FX-4300.  However, at this budget, I would most optimally prefer the FM2 platform.
ASUS AMD Radeon HD 7770 1020MHZ 2GB 1150MHZ GDDR5 2xDVI HDMI DisplayPort HDCP PCI-E DX11 Video Card
Would this be a better video card?
better compared to what GPU?
Compared to the one in the build I posted earlier.
The R7 260X performs better than the HD 7770.
Alright, is there a GPU in the $150~160 price range that is better?
Thank you for the help.
Take a look at the HD 7850 2GB.  Most are discontinued, but if you can find one for your price range, it'll be pretty good.
http://pcpartpicker.com/part/xfx-video-card-fx785acnl4
Any other ones?
Hello!
Here is my bulid: http://pcpartpicker.com/p/2uPOt
This will run any game at 1080p with high settings.
Cheers!
+1
750K/760K + R9 270 is a great combination.
Excuse my ignorance, isn't the fx 6300 a better processor, I'd be hopeing to upgrade the build gradually.
The R9 270 is a much better GPU and will get you a much nicer experience from the start.  Unfortunately, the Athlon II X4 760K is about as high as you can go.
I'm sorry, my tiny sea turtle brain doesn't understand.
So... would it be better in the long run to use the FX-6300 and throw a better gpu in later?
My second plan was to throw in a ASUS AMD Radeon HD 7770 1020MHZ 2GB then out in a second one later down the line, Thanks a lot for the help by the way.
The FX-6300 is a better processor than the Athlon II X4 750K and 760K, yes.
The FX-6300 will usually allow for better upgrade-ability, that is, if you get a decent motherboard.
The HD 7770 will run most games at low-med graphics settings.  However I would recommend against running two low end cards in what is so called "Crossfire", as the games that cannot take advantage of crossfire will not perform any better, and the games that do take advantage of this technology may come across the well documented problem known as "microstuttering".  Putting two low end graphics cards together will often cause more microstuttering than having two mid-range cards together.  I advise getting the strongest single graphics card configuration you can get before you start to consider Crossfire or SLI.
However, the 750K is still a decent chip.  You can watch a video comparison of a $80 750K vs a $200 Intel i5 here:
http://www.youtube.com/watch?v=qIT9uLDjZcg
I recommend the build Cino crated.  It's a well balanced build which will be able to perform about as well as you can ask for at this budget.
Go for the new kavari APUs
