Budget Gaming Build Help!
Hello guys!
So i am trying to build decent budget gaming computer at price of 700$ or so...
here is the link for the parts that i choose: http://pcpartpicker.com/p/K0Nb
let me know your recommendation!!
Thanks!
what do you guys think Should i go with FX-6300 or old 8150 with liquid cooler?
please let me know!
Thanks!!
Yes, this looks all around good, Though for AMD I'd say it's worth it to get 1866 ram over 1600. Also, you're missing a harddrive, unless of course you have one already, and the HAF cases are ugly as sin. Apart from that all good.
fast, cheap ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231468
It has caslantency of 11 though.. Its still really fast but I'd just get 1866MHz ram @9 Latency
